oki!
mm i suspected that that this was the case.
Possible to Tweak the automatic gearbox?
I reed that its learning by the way you drive from start. Mabe you can reset this "learning" and start over with more aggressive driving?
My problem know is when I'm driving slow with little rpm that the rpm meter goes up and then down och sometimes to high rpm for the speed. The gas response is pendling up and down.. Irritating.. :-/
I hope that the new gearbox oil make solvs this.
