Alt 25.08.2015, 10:07   #3
aw_309
More problem:
The expansionstank on the left side getting full after driving for a while and when the engine is cold down the water is still there all the way up :-/
I have had blown air in the rubber host and no problem there.
Also the temp meter is getting close to the upper marking because its low inside of water. If I turn right the meter goes up more and then down a little bit.
I tried to do exactly as you said but now this is the problem.
