Alt 26.11.2015, 09:20   #2
Matti782
Hey, i think your mazda is equipped with abs. Normaly all Xedos 6.
You can check it. Turn on your ignition. If you see a yellow light wich is named with ABS (left corner in the display device) after turning on your ignition you have ABS.
Normaly this light go out of work after the control unit was checking the system if there is no mistake.
Then you need this one:
http://www.ebay.de/itm/HERTH-BUSS-AN...cAAOSwuTxV-wTx
