Alt 01.06.2009, 19:06   #3
v6x6v6
Zitat von Phoenix Beitrag anzeigen
Hi and welcome!
You have your start problems even if the motor is cold or warm? When the engine starts it's running round or you feel some vibrations?
If the fuel pump wasn't changed, I would say this will cause the problem. You've got a new pump? Have you checked that there is no leak in the fuel system?
You can try following: ignition on - wait 3 seconds, then start. As far as I know the fuel pump will start when ignition is on, and if you wait the engine will get fuel and starts normally. If not, then there is an other problem.
If you see I already listed all info that you are asking, yes, hot and cold and fuel pump was just changed. and when motor starts it starts OK, no vibrations, ABS reset sound is imidieate also .
No leak in fuel system for sure, and I already wrote that I made this 3sec test...
