Alt 10.12.2009, 19:31   #8
Bart_PL
Hallo Jungs,
Ich sehe keine Antwort in diesen Thema.
Ich habe auch Drehzahl Problem, ich schreibe jetzt in english:
This situation is only on hot engine.
When I have for example 3000rpm on 3rd gear and press the clutch the rpm's fall down very fast and hit 1000rpm then go to 1200rpm and fall into 700rpm and stand still. Also when I have for example 3000rpm, press clutch and want to put 4th gear the rpm's fall into about 1800rpm. It's too fast.
Also when i drive on 1st gear and have for example 2500rpm the car slows down very very fast and almost stops - it's a feeling like somebody would hold the car from behind.
I drove another Xedos lately and all was ok, the rpms fell down slowly when changing gears and on the 1st gear the car was gently slowing without skipping and stopping in place.
I have checked all what's possible, spark plugs, wires, all sensors, there is no bad air comming, cooling liquid is full, no errors on computer. I have also changed the complete throttle body (from a good working xedos) - no results...
