Charging problem ( now ok ) ! Battery is still going empty...
Dear All!
I have a problem with our X 6 2.0 Automatic -92. (Now charghing ok Thanks ) There is 3 lamps [B] one [/ B] at dashboard, Brake Light, ABS and generator. When lamps are on its charching over 15V, but when lights are of its normal 14.2. But when car is parked 2 days battery is empty. I have new battery (2 times). : wall: I have also made new - cable for engine (ground) no help ... I replaced the unit with new fracture voltageregulator and new diode unit. And still same problem: motz: Then i bought brand new generator and after changing it still same problem: idiot:: wall: Lights are burning like a christmas tree .. but i still have not measured voltage. I left the car in the garage because of this major headache of it .. : shock: 2. There is strange sound at cold starts mornings from engine (not from belt side, i changed all bearings allready: wall:) sound is coming at gearbox side like a bearing problem for 3-5 minutes then all ok. Any idea!! So I need help ... All ideas are very welcome .... Best regards david |
Sorry for my bad english,
under the Accu is a 4pin cable connector. This one corroded sometimes. looks like that:( http://www.pic-upload.de/view-228117...E_291.jpg.html because of this the voltage is to high. |
Ps. Any idea of other issues??? |
@damahki: please do not post multiple. You can edit your last post if needed.
Christian |
Thank You hörnchenmeister !
Now all ok. Once again many thanks ! Br david |
No problem ;)
Hei taas!
Olen pahoillani kysyä uudestaan! Mutta ei ole mitään käsitystä siitä, miksi akku on kuollut sen jälkeen, kun viikonloppuna ... Ehkä jotkut uudet yhteystiedot ongelma! Olen aivan uusi generaattori ja sen lataaminen normaalisti nyt. BR David Boot lamp was 24/7 on now all should be ok. Yes .... |
| Alle Zeitangaben in WEZ +1. Es ist jetzt 09:51 Uhr. |
