Alt 28.05.2015, 08:29   #1
aw_309
Really powerful cold engine, warm not so fun.. :-/
Any ideas? Redoes 6 v6 1995
1 When I'm driving it in the morning the car feels really good and response fast.
When the engine is warm and after a while it feels slow and weak.. :-/
2 Also I'm thinking about getting an open airfilter to the car. Is it any special i should have?
3 Is it possible to use any chip to the car. ?
Alt 29.05.2015, 22:29   #2
Loading
Benutzerbild von Loading
Mazda Xedos 9 Facelifter
Roller Blades
Any error codes?
Maybe the knocksensor is going to die....
That's not normal.
I call it death
Alt 30.05.2015, 13:14   #3
aw_309
Why do you think its this nocksensor?
Alt 30.05.2015, 15:25   #4
Loading
Roller Blades
because if the knock sensor is broken ur engine has no power.....
but if he is really broken there must be an error code in your system....
That's not normal.
I call it death
Alt 31.05.2015, 15:22   #5
neo303
Xedos 9 KL (2.5) '96
don't do that - you will lose power. the air intake is part of the VRIS-system and has been well designed by the engineers.
yes, it's possible. but what for? unless you have a turbo charger, changing the software won't give you more power. better spend the money on new spark plugs, spark plug cables etc.
cheers
Alt 02.06.2015, 06:59   #6
aw_309
I only have one faultycode 41 vris solenoid ( 4 short - paus - 1 )
Ive had this before and it was the connection.
Also i noticed when im driving with half gasoline tank it behaves like it doesnt get enough gasoline. Maby the filter inside the tank??
It feels sometimes lite the car only sound powerful but the speed is not the same. Often when its warm. I want to feel that punch when you hit the gaspedal even in slow speed.
Its a automatic gearbox!
Ive changed the oil!
Alt 02.06.2015, 11:53   #7
Have you checked if the VRIS valves are working when the car/engine is warm?
Alt 14.06.2015, 08:36   #8
aw_309
Fuelpump
I fixed the vris 1!
But still problem with this slow reaktion and when I'm hitting the gaspedal its a quick stuttering.
I have all this time problem with a half gas tank and less that it stutter and feels weird so is it the fuel pump maby?
Is it easy to exchange? inside the car?
Alt 14.06.2015, 11:09   #9
S1PikesPeak
I fixed the vris 1!
You really should check the Fuel Pump.
Alt 15.06.2015, 11:16   #10
Yes, by messuring the fuel pressure in the rail.
Should be around 3-3,5 bar.
