Alt 08.03.2015, 13:56   #1
aw_309
Faulty code 24! Howto fix this?
24
Heated oxygen sensor (HO2S)
Bank1 - incorrect signal.
Anyone howto fix?
Mazda xedos 6 2.0 v6 1995
Alt 08.03.2015, 20:38   #2
New one?
Alt 08.03.2015, 22:19   #3
aw_309
`How do you mean?
Yes im new here since some weeks here!
Do you know anything obout the "24"? = )
Alt 09.03.2015, 13:26   #4
mboonman
You might need a new Lambda sensor.
A 10-20 pounds on ebay, but a few 100 at the mazda dealer.
Alt 09.03.2015, 23:45   #5
aw_309
Thanx
Alt 11.03.2015, 11:01   #6
aw_309
1500ppm idle, gasoline smeel mm
Is the lambdasond or the air MAS?
1500ppm idle sometimes after driving the car.
Smeels gasolin when starting
Feels slow gas respons upp till higher ppm 5000
Faulty code 24
Alt 11.03.2015, 11:25   #7
Error code 24 points to one of the following problems, found in closed loop of the right cylinder bank:
- fuel pressure
- injection value leaky
- ignition system
- leak air
- ECU
If in combination with error codes 15 or 23, you need new lambda oxygen sensors (one in each exhaust manifold).
In combination with engine stuttering or when the engine tends to stall with pressed clutch pedal, you may have a damaged (leaky) intake tube (the black plastic tube between mass air flow sensor and the throttle body.
Alt 11.03.2015, 12:28   #8
aw_309
Thanx!
I also have code 41 and i know it is vris1.
The Mas hade some loose thing inside becouse i could here it when im
Shake it slow. The air intake host is repaird now. I will try reeet the ecu.
Also one strange thing is that when the petrol messure indikator is on lower petrol rhe the car stutter and goes strange when im turning. Is it the filter in the petrol tank??
Thanx!!!
