Alt 27.12.2010, 21:07   #141
bymarek
Benutzerbild von bymarek
Xedos 9 2.5 KLZE!
Tribute 3.0i V6 AT 4x4
next year i would make holiday in spain
how much you want for painting my X9 ??
Ex Autos:
Jetzt: Tribute 3.0 V6 AT
Xedos 2.5i Schalter 2000
Alt 19.03.2011, 22:43   #142
madicioco
hy people after an engine problem we decided to do it from scratch with small additions what do you think
Hits:	356
Größe:	105,2 KB
ID:	5202   Klicke auf die Grafik für eine größere Ansicht
Hits:	347
Größe:	145,2 KB
ID:	5203   Klicke auf die Grafik für eine größere Ansicht
Hits:	356
Größe:	177,3 KB
Hits:	358
Größe:	181,4 KB
ID:	5205   Klicke auf die Grafik für eine größere Ansicht
Hits:	351
Größe:	95,3 KB
ID:	5206   Klicke auf die Grafik für eine größere Ansicht
Hits:	355
Größe:	126,8 KB
Alt 20.03.2011, 01:06   #143
the never End Story....
Gruss xedosoliker39
Alt 20.03.2011, 02:14   #144
madicioco
Gruss xedosoliker39
yes you ar right never end this story
more fotos
Hits:	355
Größe:	80,5 KB
ID:	5209   Klicke auf die Grafik für eine größere Ansicht
Hits:	356
Größe:	82,8 KB
Alt 20.03.2011, 08:56   #145
master T
nice work. I did the same with my MX-3 16v engine. Larger and polished ports, polished valves and as intake camshaft the exhaust camshaft from a miata. I suggest you to change the camshafts too!!! A german company, which is specialized in this, is called "DBilas dynamics"
The gearbox i used from a BG, do you also want to change it?
Its a really good idea to customize the ports. My 1.6 16v reached 230 km/h with the new long 5. gear. o you want to change the injectors? i used it from the 1.8 16v engine, maybe you can use some from the 2.5 V6!? I am not sure if this works on the K8.
A friend of mine swapped a 2,5 KLZE in a MX-3, he was really satisfied after using a higher gasoline pressure valve. I also tried it in his car, awsome difference. Maybe you can also ad this on you engine, as long as its still not replaced
The problem was, i drove 2000km and the engine blows on the german autobahn. I suggest you to enlarge you oilcooler!!
In addition i add some pictures for the xedos 6 1.6 16v engine drivers. Nearly same engine as im MX-3
Hits:	341
Größe:	98,4 KB
ID:	5220   Klicke auf die Grafik für eine größere Ansicht
Hits:	323
Größe:	49,5 KB
Geändert von master T (20.03.2011 um 11:28 Uhr)
Alt 20.03.2011, 10:32   #146
more fotos
But it is a great project.
I'm on the end result look forward to!
Cylinder head looks delicious ever made ​​.. there should jump out at the end of minimum 20 hp!
Gruss xedosoliker39
Alt 22.03.2011, 21:33   #147
madicioco
hi thanks
I will try to do something different from what is normally, the camshafts will not change them at the moment, the gearbox will remain the same, you just change the injectors with the 2.5 V6, K & N filter and a free disposal and I think I'll win something extra
y am looking for a chip power where they can find something
Alt 22.03.2011, 22:04   #148
DGFxedos6V6
Benutzerbild von DGFxedos6V6
Xedos 6 2.0 V6 SE1
here : http://www.xedos-shop.de/product_inf...28df7cbf91757b
But it´s a lot of money for a few more Horsepower
mfg Chris
Alt 23.03.2011, 20:56   #149
madicioco
I knew this but I thought there are others
and it really is a bit expensive for horses who removed
Alt 23.03.2011, 21:25   #150
DGFxedos6V6
Xedos 6 2.0 V6 SE1
maybe if you look for tuningparts for Ford Probe 2 2.5 in the USA
http://eng.smchiptuning.com/1951/ford-probe-2.5-v6-164
mfg Chris
Geändert von DGFxedos6V6 (23.03.2011 um 21:33 Uhr)
