Alt 13.09.2010, 19:46   #31
born2die
Benutzerbild von born2die
Mazda X6 '97 2,5l 163PS
Glaub eher das sind LEDs aber ich warte mal auf eine Antwort. Sieht hammer geil aus.
das ist Xenon die haben da alles überall Xenon verbaut nur wir dürfen sowas nicht
Alt 13.09.2010, 23:40   #32
Rooz21
Benutzerbild von Rooz21
Xedos 6 1,6 Serie 2
ja da sagste was... leider
@ w00lf: tippe 100% auf xenon, weil guck dir mal die refkletion aufn boden an
PS: wär aber vieeeeeeeel zu auffällig, xenon als abblendlicht sowie als nebler gleichzeitig
Alt 14.09.2010, 07:22   #33
Artemmka
Benutzerbild von Artemmka
Zitat von Rooz21 Beitrag anzeigen
... you are using FK lower springs, I've got the same but my car isn't so low as yours. are you satisfied with them springs?
Yes, i`m fully satisfied, but i thought that it will be much lower, when i compare old spring with new one (you can see on picture difference). I like it more, because the vibration is gone away (i had low vibration when acalarating at 2300-2700rpm). Perfect look!
Hey, very nice.
Which bulbs did you use in this picture?
It`s not a Xenon, it`s just Philips Blue vision H3 It looks different in different angle.
I use fog lamps only for day running lights. I have Xenon 6000K in main lights H1.
But i plan to put Xenon in fog too in future.
Mit freundlichen Grüßen,
Artem (рус.Артём)
Alt 14.09.2010, 07:35   #34
Artemmka
Gkiokan
Swap was made in service. But i regularly was there and looking and helping.
After the swap was made i spent a lot of money and time to make all to the end.
I`ll add new post about swap in few days. I`ll write everything what i have made during swapping.
I had 215x45x17, now i put 205x50x17
The alloys rims of M6 are very heavy, on 205x50 it`s better running, but i need to control spinning.
I thought on your idea, but you right, not so insane power added during swap
Sure, safety first, then other things.
Artem (рус.Артём)
Alt 14.09.2010, 07:38   #35
Artemmka
I WOULD LIKE TO SAY THANK YOU TO ALL COMMENTS!
THANK YOU FOR ALL RESPECT!
P.S. sorry that i use english language on your forum
Artem (рус.Артём)
Alt 14.09.2010, 17:03   #36
Are you serious? My Bluevision looked so much yellower than yours, unbelievable.... So i put in the Osram Nightbreaker again, they are a little bit more "white" (at least at night).
No problem. Sorry for writing in german on your thread. It was just a discussion wheter you put in Xenon or LEDs.
Alt 15.09.2010, 07:39   #37
Artemmka
Maybe on the photo it looks so bright and white.
In real life it`s not white!
When i bought i thought that it will look better.
But you know, that i put the same mine Philips H3 in Mitsubishi Galant, it looks really white.
I think the problem is that we have Lens there.
Artem (рус.Артём)
Alt 15.09.2010, 10:58   #38
Artemmka
KL swap
Engine from: Mazda 626 2.5 V6 1993 (automatic)
Inject manifold and throttle body from 626 2.5 too.
ECU: KL05
Airflow meter: KL02
Wiring is mine KF (stock)
I have 1-th generation X6 and the engine was from 626 of 1-th generation too.
So all sensors are in place.
Put my 2.0 KF manual transmission.
Drive shafts were from X6 KF. Now i put of 626 2.5 automatic (i thought that from KL they are larger, but they are the same)
Rear engine mounting is new, from 2.5 engine (it`s larger)
New clutch and bearing.
Changed rods, oil seals, gaskets of valve cover, new water pump, new tensioner, new timing belt, all rolls, new oil, filters, NGK wires, denso spark plugs.
I made everything in service, only swap and engine preparing.
After that spend a lot of time on other things, cleaning, putting everything in correct place.
Here are some photos.
Name:	01042010489 640x480.jpg
Hits:	1025
Größe:	64,0 KB
ID:	4703   Klicke auf die Grafik für eine größere Ansicht
Name:	01042010490 640x480.jpg
Hits:	1026
Größe:	83,7 KB
ID:	4704   Klicke auf die Grafik für eine größere Ansicht
Name:	05042010516 640x480.jpg
Hits:	1076
Größe:	79,7 KB
Hits:	1061
Größe:	75,3 KB
Artem (рус.Артём)
Alt 13.10.2010, 08:30   #39
Artemmka
Door panels & Chrome holders
The door panels are made by myself. I spent 4 evenings.
Handles are from Xedos 9 2001 year.
Artem (рус.Артём)
Alt 13.10.2010, 08:34   #40
Wow, looks pretty nice.
Especially those door handles. Where did you get them?
regards, Wolfgang
