Alt 11.04.2011, 07:32   #61
Artemmka
Benutzerbild von Artemmka
I know that it is possible without any large changes, put from MPS 6 also.
But i can`t find here in Latvia any MPS for parts. New are too expensive.
Mit freundlichen Grüßen,
Artem (рус.Артём)
Alt 11.04.2011, 07:56   #62
Eddyk
Have you take only Brakedisc from Mazda 6 or the brake system?
Alt 11.04.2011, 08:01   #63
Artemmka
Please look. I changed only.
Zitat von Artemmka Beitrag anzeigen
Front brake calipers of Mazda 6 I generation 2.0 -2.3 l.Also brake pads.
Front discs of Mazda 6 I generation 2.0 -2.3 l
My future plans, to check if it is possible to put main brake cylindr and vacuum from 6256 GF or Premacy.
Artem (рус.Артём)
Alt 12.04.2011, 14:23   #64
Eddyk
Brake System is the same, only the ABS ECU is another than xedos, by premacy i dont know.
Alt 12.04.2011, 14:30   #65
Artemmka
Probably, but i compared 626 GE and X6, they are a little bit different.
Premacy should be as 626 GE, as i know the same platform.
Artem (рус.Артём)
Alt 12.04.2011, 17:29   #66
Platform of Xedos 6 = platform of 626 GE.
Shouldn't be different.
regards
Alt 12.04.2011, 17:50   #67
Same platform does not mean identical brakes and completely identical parts.
Ok, 626 GE, Xedos 6, MX-6 and Ford Probe II are using the same platform, the same technic, same engines - but there are a lot of differences in detail.
And no, Premacy does not use the GE-platform.
Alt 12.04.2011, 19:43   #68
Artemmka
Sorry, didn`t write till the end.
I meant that 626 GF = Premacy = 323 BJ
Artem (рус.Артём)
Alt 14.04.2011, 21:54   #69
Artemmka
Rebuiled heads
Today took rebuilded heads.
Was made:
1. polished surface
2. new valve guides on exhaust valves
3. polished valves
4. valves and valve seats were machined. Made stock angles. Tested by vacuum.
5. i washed heads using karcher with 100`C temperature
Hits:	452
Größe:	158,9 KB
ID:	5305   Klicke auf die Grafik für eine größere Ansicht
Hits:	443
Größe:	136,8 KB
ID:	5306   Klicke auf die Grafik für eine größere Ansicht
Hits:	435
Größe:	143,6 KB
Hits:	441
Größe:	91,0 KB
ID:	5308   Klicke auf die Grafik für eine größere Ansicht
Hits:	483
Größe:	95,3 KB
Artem (рус.Артём)
Alt 18.04.2011, 09:58   #70
Artemmka
Valve covers
All Saturday spent for cleaning.
Take a look.
I`ll polish them with aluminium paste later.
Artem (рус.Артём)
Geändert von Artemmka (18.04.2011 um 10:05 Uhr)
