User und ihre Autos Stelle Dein Auto hier der Community vor.
11.04.2011, 07:32
#61
I know that it is possible without any large changes, put from MPS 6 also.
But i can`t find here in Latvia any MPS for parts. New are too expensive.
Mit freundlichen Grüßen,
Artem (рус.Артём)
Diese Einblendung wird nicht mehr angezeigt, sobald Du Dich
registriert und angemeldet hast.
11.04.2011, 07:56
#62
Have you take only Brakedisc from Mazda 6 or the brake system?
11.04.2011, 08:01
#63
Zitat von
Eddyk
Please look. I changed only.
Zitat von
Artemmka
Front brake calipers of Mazda 6 I generation 2.0 -2.3 l.Also brake pads.
Front discs of Mazda 6 I generation 2.0 -2.3 l
My future plans, to check if it is possible to put main brake cylindr and vacuum from 6256 GF or Premacy.
Artem (рус.Артём)
12.04.2011, 14:23
#64
Zitat von
Artemmka
Brake System is the same, only the ABS ECU is another than xedos, by premacy i dont know.
12.04.2011, 14:30
#65
Zitat von
Eddyk
Probably, but i compared 626 GE and X6, they are a little bit different.
Premacy should be as 626 GE, as i know the same platform.
Artem (рус.Артём)
12.04.2011, 17:29
#66
Zitat von
Artemmka
Platform of Xedos 6 = platform of 626 GE.
Shouldn't be different.
regards
12.04.2011, 17:50
#67
Same platform does not mean identical brakes and completely identical parts.
Ok, 626 GE, Xedos 6, MX-6 and Ford Probe II are using the same platform, the same technic, same engines - but there are a lot of differences in detail.
And no, Premacy does not use the GE-platform.
12.04.2011, 19:43
#68
Sorry, didn`t write till the end.
I meant that 626 GF = Premacy = 323 BJ
Artem (рус.Артём)
14.04.2011, 21:54
#69
Rebuiled heads
Today took rebuilded heads.
Was made:
1. polished surface
2. new valve guides on exhaust valves
3. polished valves
4. valves and valve seats were machined. Made stock angles. Tested by vacuum.
5. i washed heads using karcher with 100`C temperature
Artem (рус.Артём)
18.04.2011, 09:58
#70
Valve covers
Artem (рус.Артём)
Geändert von Artemmka (18.04.2011 um 10:05 Uhr)
