Alt 01.02.2010, 19:55   #1
damahki
Charging problem ( now ok ) ! Battery is still going empty...
Dear All!
I have a problem with our X 6 2.0 Automatic -92. (Now charghing ok Thanks )
There is 3 lamps [B] one [/ B] at dashboard, Brake Light, ABS and generator.
When lamps are on its charching over 15V, but when lights are of its normal 14.2.
But when car is parked 2 days battery is empty.
I have new battery (2 times). : wall:
I have also made new - cable for engine (ground) no help ...
I replaced the unit with new fracture voltageregulator and new diode unit. And still same problem: motz:
Then i bought brand new generator and after changing it still same problem: idiot:: wall:
Lights are burning like a christmas tree .. but i still have not measured voltage.
I left the car in the garage because of this major headache of it .. : shock:
2. There is strange sound at cold starts mornings from engine (not from belt side, i changed all bearings allready: wall sound is coming at gearbox side like a bearing problem for 3-5 minutes then all ok. Any idea!!
So I need help ...
All ideas are very welcome ....
Best regards david
Geändert von damahki (08.02.2010 um 18:04 Uhr)
Alt 01.02.2010, 20:07   #2
hörnchenmeister
Sorry for my bad english,
under the Accu is a 4pin cable connector. This one corroded sometimes.
looks like that
http://www.pic-upload.de/view-228117...E_291.jpg.html
because of this the voltage is to high.
Alt 01.02.2010, 20:22   #3
damahki
looks like that
Ok tomorrow i will check it. It could be it begauce car is old but km only 133000. Thank You i will check it. Br david
Ps. Any idea of other issues???
Alt 03.02.2010, 20:19   #4
@damahki: please do not post multiple. You can edit your last post if needed.
Alt 04.02.2010, 19:05   #5
damahki
Thank You hörnchenmeister !
Now all ok.
Once again many thanks !
Br david
Alt 04.02.2010, 20:46   #6
hörnchenmeister
No problem
Alt 08.02.2010, 12:49   #7
damahki
Hei taas!
Olen pahoillani kysyä uudestaan! Mutta ei ole mitään käsitystä siitä, miksi akku on kuollut sen jälkeen, kun viikonloppuna ... Ehkä jotkut uudet yhteystiedot ongelma! Olen aivan uusi generaattori ja sen lataaminen normaalisti nyt.
BR David
Boot lamp was 24/7 on now all should be ok. Yes ....
Geändert von damahki (08.02.2010 um 20:36 Uhr)
