first , i want to apologise for my bad english.
Do not apologize. I`m not good in it too.
does the dual back contact conector ftis ok in front signal light??or do you have to do some modification?
It fits, but you need to modified keepers.
Turn light signal has 3. Rear 2 contact has 4 keepers. But it is only one modification, it`s not a problem.
when you turn signal on is brighter than parkinglight light?i guess is just like on the back lights.
It is much brighter. Sidelight will be used in 5W and turn in 21W
i like yours folding mirrors...for a long time i dream at those mirrors
can i put some folding mirrors or i had to modifide mine with some parts from the folding ones?does it has a litle motor wich folds the mirrors?
NO! You need to use folding ones. You can just put your outside parts, to do not paint. And leave your triangle on a door.
why do you change the 215/45/17 tires?it was rubbing in fenders or shock absorber?
No rubbing.Tire were inside of an archs. Everything fits fine on a stock federn. At that moment i have no FK springs.
I would like something bigger 45>50, because of the roads. On 205 runs better.
225/45/18 fits or it to wide and tall?
On Mazda original rims with normal ET it will be fine.
But i know that 35 will be better for our X.
xedos will be slower with wider tires?
I noticed that it is slower.
