Alt 18.10.2015, 21:48   #11
aw_309
I mean the "flywheel" between engine and gearbox.. Don't know the technical english word ;-/
Can i take the flywheel from my automatic 2.0 v6 engine att put on the mx-6 2.5 engine if its been with a manual gearbox!?
Wielen Dank! = )
Alt 18.10.2015, 21:49   #12
Ok, understood!
Yes, flywheel is the right english word for that!
Mazda RX-7 SA ist gerade online   Mit Zitat antworten
Alt 18.10.2015, 21:56   #13
aw_309
Ok Great!! = )
And if I want more power i use the KL-ZE air intake manifold instead of the KL-DE? How much does this? = )
Alt 18.10.2015, 23:23   #14
aw_309
Last question about this.. i think..
If I Take a Xedos 9 KL-DE engine the problem is the intake manifold is to big for Xedos 6? It will not fit in the engine room?
The MX6 engine is rare. Easier to get Xedos 9 2.5 v6 engine!
Is the Xedos 9 2.5 v6 also easy to swap like the mx6 engine?
Alt 19.10.2015, 04:22   #15
hörnchenmeister
That is no problem, cause you use the intake manifold from your X6.
It make sense to put the throttle from 2.5l on your X6 manifold.
I dont know about the one from X9, Probe and MX6 throttle fits to X6 manifold.
Compare with pictures will help you.
Alt 20.10.2015, 19:44   #16
aw_309
DISTRIBUTOR and THROTTLE
DISTRIBUTOR
Do I have to have the distributor from MX6 KL 2.5 v6 or can I use from Xedos 6 KF 2.0 v6?
THROTTLE
Can i use the KF 2.0 v6 Throttle to MX6 KL 2.5 v6 engine?
Any more I have to have to make it work?
I thought i could use the block and head and move the other parts from my 2.0 v6 engine?
I also se that part number is different if you have manual and automatic box for throttle
and part picture is different! :-/
Anders
Geändert von aw_309 (20.10.2015 um 20:26 Uhr)
Alt 20.10.2015, 21:30   #17
hörnchenmeister
You must use the DISTRIBUTOR from your X6 cause there different types.
You can use the throttle from X6 but with the one from MX6 it accerlerate better cause the diameter is bigger.
Alt 20.10.2015, 21:36   #18
aw_309
Ok So it will fit to the 2.5l head?
I have 7 ignition cabels. one for the ignition coil!
Alt 20.10.2015, 21:39   #19
hörnchenmeister
Yes you must change the complete, not only the cap.
Ignition must be regulatet after that with strobo light and the mark on the timing belt cover.
Alt 20.10.2015, 21:48   #20
aw_309
Should you set the timing for 10 or do you think 13-14 is ok?
yes! ok thanx for the help here!!
I think I've got it now = ))
Thank you very much!! = )
