Alt 03.06.2009, 10:42   #11
v6x6v6
Here is the latest, I made LED diagnostic.
First LED flashed 2 flashes, 3 flashes, 4 flashes. I assume codes are
02
34
then I made reset and checked again = no error codes
turned the car on
made test = 4 flashes Error 04
reset the codes
checked codes = no error codes
turned the car on
again 4 flashes
So obvious error
04 'NE1' camshaft/crankshaft position sensor
Where is this bastard?
Alt 05.06.2009, 17:11   #12
v6x6v6
Hi alle!!
Ich habe das problem 'solved'
Es va Vertailler - habt gewekselt un wagen startet nur in 1 sekunde!!
So alle mit diesen problem - Vertailler!!
Auf vidersen
Ich weiss mein deutch is ......
Alt 05.06.2009, 18:05   #13
kitzi83
Benutzerbild von kitzi83
Zitat von v6x6v6 Beitrag anzeigen
Hi alle!!
Auf vidersen
hello!
thanks for the solution because i ve the same problem so now i know what i ve to do!
