Alt 27.10.2015, 20:31   #1
aw_309
KL engine from ford Probe KL02
Hi!
I found on the engine its says (KL02) on mass airflow meter.. Anyone what does it mean?
Thanx!
Alt 28.10.2015, 05:42   #2
hörnchenmeister
Its a normal KL you can use.
The Air mass sensor is not need for your purchase.
Alt 28.10.2015, 06:52   #3
aw_309
How do you mean?
That I use the KF 2.0 air mas?
Alt 28.10.2015, 11:25   #4
Zitat von aw_309 Beitrag anzeigen
air mas?
It needs to work with the ECU from the Car.
So for example, if you take the air mass sensor from Xedos 9, it won't work in Xedos 6. Because in both cars sensor and ECU are different!
