Alt 25.11.2015, 12:28   #1
aw_309
ANTRIEBSGELENK - ABS?
Hello! i need new ANTRIEBSGELENK. IS the Xedos 6 1995 V6 with or without ABS system?
Thanx!!
Alt 26.11.2015, 09:20   #2
Matti782
Hey, i think your mazda is equipped with abs. Normaly all Xedos 6.
You can check it. Turn on your ignition. If you see a yellow light wich is named with ABS (left corner in the display device) after turning on your ignition you have ABS.
Normaly this light go out of work after the control unit was checking the system if there is no mistake.
Then you need this one:
http://www.ebay.de/itm/HERTH-BUSS-AN...cAAOSwuTxV-wTx
Alt 26.11.2015, 12:16   #3
Please double check dimensions (mainly no. of teeth) as per second picture.
Alt 05.12.2015, 00:27   #4
H@ns
Benutzerbild von H@ns
buy it with "ABS-Ring". With my X6 V6 from 1992, 1996 and 1999 it was always the right one.
