Alt 19.02.2016, 09:39   #1
aw_309
Anyone knows ehat this two connections is??
now when we almost is done with the engine swap to the 2.5 V6 we have two electric connections we don't understand fully.
Do you see what it could be?
The grey is near the top and it goes under some place and the black to the right comes from gearbox. The grey for the tempsensor is all ready at place.
hmmmm :-/
Anyone?
THANKS!
Hits:	606
Größe:	126,5 KB
ID:	8197   Klicke auf die Grafik für eine größere Ansicht
Hits:	633
Größe:	104,6 KB
Alt 19.02.2016, 10:04   #2
What about the gray an nock-sensor?
Alt 19.02.2016, 10:56   #3
aw_309
ah!
Good idea. Where is the connection located`?
Is it this type? (check images)
Name:	100-Genuine-OE-QUALITIY-Knock-Sensor-ZJ01-18-921-FOR-Mazda-Millenia-MX-3-MX-6.jpg
Hits:	597
Größe:	169,9 KB
Alt 19.02.2016, 11:40   #4
hörnchenmeister
The X6 serie2 has no knock sensor.
You don´t need it on KL when your KF dosn´t had one.
Location is under the cooling pipe in the center between the cylinder banks.
Alt 19.02.2016, 13:00   #5
aw_309
oki now i know
hmm and the black connection from automatic gearbox?
Maby they grey is for the ignition coil.
