Interieur
Alt 01.03.2016, 21:28   #1
aw_309
Connect steering wheel from mazda 6 to xedos 6
Hi!
my question is about the airbag. Do you think the airbag system and connections could work with the steering wheel from mazda 6 ?
Thanx! = )
Alt 02.03.2016, 08:25   #2
Many people out there are using Mazda 6 GG steering wheel in a Xedos 6 without having trouble.
No idea if the connectors are 100% identical or if there's a need to adapt, but technically it works.
But be careful: airbags are highly dangerous explosive devices. Improper handling can be deadly. Don't handle with airbags if you do not exactly know what you are doing.
Alt 02.03.2016, 09:19   #3
aw_309
Yes with the airbag you have to handle it with care. Leave the battery off during the night before i think is enough.
Do you now if anyone has some guidelines for the connetions?
Alt 02.03.2016, 09:22   #4
Perhaps you could ask the user Artemmka
Alt 02.03.2016, 09:38   #5
aw_309
I did!! = )
Do you also know what typ of led lamps for the speedmeter and rpm meter and so on? I will have stronger lights. How many and types? t10? I bought also metal rings to add. It will be nice = )
