Alt 27.08.2015, 12:32   #11
Zitat von aw_309 Beitrag anzeigen
Not so much cost because the seats was from blocket and used. Audi a6 2007 sport. My friend removed the fittings for the old seats and welded to the new seats. Quite simple.
Interesting!
Witch cabel (color) should connect with the original contact?
I think this is your smallest problem, if you want to use the Airbag from Mazda 6! You only need to get wiring diagram of both, which is doable.
The biggest challenge would be to be sure that the new Airbag will work with the System in the Xedos!
Alt 27.08.2015, 13:00   #12
aw_309
Yes i know that but i have but cant find the proper info. No colors or info about the connections to the steering wheel ;-(
Anyone? Will the connections fit between steering wheel mazda xedos 6 1995 and Maxda 6 Atenza 2004?
Alt 27.08.2015, 15:26   #13
I told you: The connection (which cable to which cable) or type of plug is your smallest problem.
I also don't think, that someone here will be able to help you to find out if the Airbag will work.
I think you need try to find some info in the net (Russian or US poeple are more likely to try such), try to get some info from Mazda directly (will be not really easy I think) or to get hold of an Airbag-System Speciallist (try to ask/contact the supplier of the airbag).
Alt 27.08.2015, 20:35   #14
hörnchenmeister
You can ask the guy from this thread
http://www.xedos-community.de/showth...=43856&page=29
he´s got a different steering wheel in his X.
Alt 28.08.2015, 09:29   #15
aw_309
Thanx! = )
Alt 21.03.2016, 21:15   #16
aw_309
UPDATE!
18" alloys with new 225/40r18 and Mazda 6 Steering Wheel 2004! = )
Name:	Foto 2016-03-21 18 40 13.jpg
Hits:	936
Größe:	201,5 KB
ID:	8221   Klicke auf die Grafik für eine größere Ansicht
Name:	Foto 2016-03-16 17 45 15.jpg
Hits:	859
Größe:	191,1 KB
ID:	8222   Klicke auf die Grafik für eine größere Ansicht
Name:	Foto 2016-03-19 18 47 25.jpg
Hits:	878
Größe:	231,1 KB
Name:	Foto 2016-03-20 14 16 11.jpg
Hits:	872
Größe:	155,6 KB
ID:	8224   Klicke auf die Grafik für eine größere Ansicht
Name:	Foto 2016-03-19 10 31 16.jpg
Hits:	850
Größe:	199,7 KB
Alt 21.03.2016, 21:25   #17
Nice!
Which rim offset?
Airrbag system is now working without fault code?
Alt 21.03.2016, 21:37   #18
aw_309
18x8j
ET 40
73,1 -> 67,1
YES the airbag signal is good now = )
