Alt 09.03.2016, 10:15   #1
aw_309
Lower the choke?
Hello!
Is it possible to lower there shoke in rpm?
After the engine swap from 2.0 to 2.5 the choke when the car is cold its to high in rpm i think (2000 rpm first 5secunds then 1700 rpm)
Should it be around 1300 rpm when its choked?
Thanks!
Alt 09.03.2016, 11:24   #2
Engines with fuel injection don't have choke!
Are you talking about idle rpm?
If yes, have you:
- completelly cleaned the throttle valve (incl. disassembly of idle adjusting screw)?
- adjusted idle rpm after it as per instructions?
Alt 09.03.2016, 11:36   #3
aw_309
Hello! = )
ok no choke? But when its cold its always much higher then 5 minutes later. Then 700rpm.
Do you have instructions? for the idle settings? =)
No i havent cleaned it! I use the throttle house from the 2.5l v6.
Alt 09.03.2016, 20:08   #4
Zitat von aw_309 Beitrag anzeigen
ok no choke?
Definitely not!
It is only at engines with carburator.
This is different!
This is higher idle rpm for faster KAT warmup.
Here in german: LINK
Please do it!
You can see pictures in my thread: LINK
And also here: LINK
Please also disasemble the idle adjusting screw as shown on my pictures.
Alt 10.03.2016, 09:09   #5
aw_309
Thanks! = )
I also found this one.. The guide!
http://www.mx6.com/forums/2g-mx6-gen...solutions.html
I guess that can be aplyed for the Xedos 6 with 2.5l V6 engine also?
Alt 10.03.2016, 11:22   #6
The main point is which diagnostic system and ECU you have.
I guess both of them are still from your X6 KF, right?
Then you need to check how to do it at X6.
But I gueass, that all (Xedos 6 & 9 and MX-6) will have this "TEN" pin at Diagnostic port.
Alt 10.03.2016, 14:33   #7
aw_309
Yes!
What do you think of my setting ( se picture)
What ive red is that this scruv should barely touch the gas throttle but
Here its very more than that.
I will do a real deafult setting tomorow from the guide!
Hits:	420
Größe:	90,0 KB
Alt 10.03.2016, 18:33   #8
This is not the screw I was talking about....
This is the idle adjusting screw I was talking about:
The screw you marked (left one, red marked) shouldn't be changed. But you can adjust the other one if there is a tolerance (right one, green marked).
Alt 10.03.2016, 19:11   #9
aw_309
ok great! = )
Thanks.
Do you now where to find a electric diagram for Xedos 6 1995?
I need for the steering wheel (airbag, horn mm)
Alt 10.03.2016, 19:20   #10
See the Link in the other Thread.
