Alt 30.07.2011, 11:31   #111
Zitat von claude7 Beitrag anzeigen
does the dual back contact conector ftis ok in front signal light?? when you turn signal on is brighter than parkinglight light?i guess is just like on the back lights.
Yes. And yes.
regards, Wolfgang
Alt 30.07.2011, 17:27   #112
Artemmka
Benutzerbild von Artemmka
first , i want to apologise for my bad english.
Do not apologize. I`m not good in it too.
does the dual back contact conector ftis ok in front signal light??or do you have to do some modification?
It fits, but you need to modified keepers.
Turn light signal has 3. Rear 2 contact has 4 keepers. But it is only one modification, it`s not a problem.
It is much brighter. Sidelight will be used in 5W and turn in 21W
i like yours folding mirrors...for a long time i dream at those mirrors
can i put some folding mirrors or i had to modifide mine with some parts from the folding ones?does it has a litle motor wich folds the mirrors?
NO! You need to use folding ones. You can just put your outside parts, to do not paint. And leave your triangle on a door.
why do you change the 215/45/17 tires?it was rubbing in fenders or shock absorber?
No rubbing.Tire were inside of an archs. Everything fits fine on a stock federn. At that moment i have no FK springs.
I would like something bigger 45>50, because of the roads. On 205 runs better.
225/45/18 fits or it to wide and tall?
On Mazda original rims with normal ET it will be fine.
But i know that 35 will be better for our X.
xedos will be slower with wider tires?
I noticed that it is slower.
Mit freundlichen Grüßen,
Artem (рус.Артём)
Alt 30.07.2011, 19:18   #113
claude7
10x
thank's for your answears...i give you a beer when you came in romania
225/35/18 it seems to be for xedos 6 but 225 it so wideand 35 so small...
i ask because i have found some rx8 wheels wich has 225/45/18 the original dimension...and i don;t have now the money for others smaller tires...so 205>215>225?for a fast xedos?
Alt 31.07.2011, 10:46   #114
Artemmka
Ok.Let`s deal. ))
I know that RX8 whel fits great on Xedos.
I saw not one X6 on RX8 wheels.
Put 225x40
Artem (рус.Артём)
Alt 31.07.2011, 12:27   #115
claude7
rx8
it sure looking great but i'm afraid that tires are too wide and tall, but my xedos isn't lowered...maybe i should give a try
this guy puts 205/40/18 tires
Hits:	852
Größe:	84,7 KB
ID:	5717   Klicke auf die Grafik für eine größere Ansicht
Hits:	816
Größe:	55,9 KB
Alt 31.07.2011, 15:33   #116
Artemmka
I prefer 205 wide.
For Xedos it will be much ligheter and better running.
Those rims looks great.
Artem (рус.Артём)
Alt 31.07.2011, 16:15   #117
...i have found some rx8 wheels wich has 225/45/18 the original dimension...
Thats WAY too much. 225/35 R18 would be the right dimension for the V6.
regards, Wolfgang
Alt 03.08.2011, 17:22   #118
claude7
but 225 isn't to wide for xedos? there is a special topic about bigger wheels for xedos 6 on this site?
Alt 03.08.2011, 19:32   #119
Daggy
no, 225 is ok
Alt 03.08.2011, 20:44   #120
I have 225/35R18 on X6 since 7 or 8 years with 3 different rims. It's perfect up to 8x18", when body edges are raised.
