Alt 18.02.2016, 10:29   #51
hörnchenmeister
The first one could be the watertemp sensor nearby the fillcap.
Not all Mazda V6 have there a sensor.
Can´t you compare with your KF?
Alt 18.02.2016, 11:04   #52
Zitat von aw_309 Beitrag anzeigen
"In your case only one hole of the bearing body will match with screwed hole of the block?"
Yes the 2.5 block, only one hole will fit the bearing body!
Have you checked Nr. 3?
As below:
3.) Please check, if at KL block there is a screwed hole at nr. 3.
If at hole Nr. 3 there is a screwed hole at the block you could drill a hole in the bearing body and use that for second screw.
Alt 18.02.2016, 11:09   #53
Please check. Maybe this hole will fit with Nr. 3 of your bearing body:
Alt 19.02.2016, 09:31   #54
aw_309
Yes i will check! = )
I must say thanks for the help here! Without you guys it would be much more problems and stress for me.
What do you think about the connections??
The grey one and the black from the gearbox?? :-/
The grey one is not the tempsensor.
Alt 02.03.2016, 16:14   #55
aw_309
Today I picked upp the car and checked it. I noticed that the vris system doesnt react. The two wings with the vaccum doesnt move when im use the gas trohtle.
The mechanic has no idea. :-/
I will check by myself if there is faulty codes.
Any idea?
Thanks
Alt 02.03.2016, 18:53   #56
hörnchenmeister
For understanding here are some desriptions
https://www.youtube.com/watch?v=W1Pwa8wQu8k
Alt 03.03.2016, 10:05   #57
aw_309
I understand what VRIS does but it will not start turning around the right RPM.
Alt 03.03.2016, 14:23   #58
hörnchenmeister
Did it work before you have swap the the engine?
Are all electrical connections ok.
The vacuum hoses must be ok as same.
The two VRIS elements have each a rod. This could be rusted.
And sometime the vacuum is not seal. Then it works not, too.
Alt 16.03.2016, 21:57   #59
aw_309
Strange but after some days it works again!
No faulty codes before.
Alt 16.03.2016, 22:02   #60
aw_309
I missed to remove the throttle house adapter plate when we used the 2.5 throttle house. That sits between throttle house and the intake manifold. Will it do a lot to remove it? Ive seen that others with 2.5 V6 does not have it attached!
What do you think?
