Alt 16.03.2016, 22:24   #61
Zitat von aw_309 Beitrag anzeigen
I missed to remove the throttle house adapter plate when we used the 2.5 throttle house. That sits between throttle house and the intake manifold. Will it do a lot to remove it? Ive seen that others with 2.5 V6 does not have it attached!
What do you think?
I don't really understand waht you mean.
Alt 17.03.2016, 06:49   #62
aw_309
Lite bit hard to explaine but ill try again = )
on Xedos 6 where the Trottle body is located there is a metal plate between the
intake manifold to the throttle body.
INTAKE MANIFOLD ---> metal plate (with four screw) ------> Throttle body
On the 2.5l V6 (mx6, 626 Ge, ford probe) they use no metal plate.
Will the car go better without the plate?
Thanx
Alt 18.03.2016, 10:47   #63
How thick is the plate? Which material? Which color?
Maybe you mean the metal gasket....
If yes, there should always be a gasket!
Alt 18.03.2016, 13:29   #64
aw_309
Its not a gasket!
Plate, about 5mm thick.
Geändert von aw_309 (18.03.2016 um 17:48 Uhr)
Alt 18.03.2016, 17:49   #65
aw_309
Metal plate
Hits:	596
Größe:	118,2 KB
Alt 21.03.2016, 11:16   #66
Aha, interesting!
And there are then 2 gaskets?
I guess it is only because of distance problems. I see no other reason to mount such plate.
The plate has no other holes? Or something other is attached to the plate?
Alt 06.04.2016, 18:46   #67
aw_309
Vibrations around 1300rpm not driving
Vibrations around 1300 rpm when im not driving the car. In neutral and park
Its like: wrrrr-----wrrrr------wrrrr------wrrrrr
Could it be the engine mounts? There is three. Witch one is it often if there a problem with them?
What could it be else ? The engine shakes to much then normal.
Thanks!
Alt 07.04.2016, 11:18   #68
If the engine is off, can you shake the engine? If there is no clearance in the engine mounts, its another problem.
I would spend the money and buy new air hose between throttle and filter.
Alt 07.04.2016, 21:16   #69
aw_309
No i cant move it!
yes I will buy new but this shaking is someting else.
I have fault code 25.
Solenoid - fuel regulator.
Checked the vaccum today and there is vaccum. Strange is that i dont have 12volt to the solenoid when the engine is running but maby its only sometimes?
Alt 08.04.2016, 11:06   #70
No i cant move it!
Then I think this is not the problem.
OK, this could mean problem with the fuel pressure.
Which solednoid have you used? From the KL or from your KF?
