Alt 08.04.2016, 19:12   #1
aw_309
Front schassi vibration steering wheel!! ?
Hello! Need help!!!
Vibrations in the steering wheel.
Sometimes more.
Driving arround 100-130km/
Both D drive and N neutral
New brake discs. Works really good
New wheels and tires.
Something in the front chassi is the problem but i cound not find it.
Its realy hard and everything is oki.
Any ideas??? :-/
Alt 08.04.2016, 19:35   #2
hörnchenmeister
Check your drive shafts.
Alt 08.04.2016, 19:48   #3
aw_309
Both outer drive shafts new! :-/
Alt 09.04.2016, 08:39   #4
hörnchenmeister
The right inner sight had make this problem in the past several times.
When thats Ok check the wheel bearings.
Right side is in my description te the long shaft which you had problems with the screws on engine block.
Alt 10.04.2016, 11:32   #5
aw_309
it feels like it comes and goes... sometimes more vibrations..
I gues it must be someting in the right front chassi.
if i put the automatic in neutral its the same
Alt 16.04.2016, 07:42   #6
aw_309
Hello!
I was the new breakes that was on!
Fixed!
Alt 17.04.2016, 19:40   #7
Gratulation!
Alt 18.04.2016, 11:22   #8
How you fixed it?
Incorrect mounting?
